Nnbs driveshaft limit?
#21
You might be ok. Just make sure you have enough in and out play for the driveshaft so nothing binds when the suspension compresses.
My NBS def needed a modded shaft. The old one won't fit at all.
#22
#28
I start feeling mine at about 35 or so.... I have a new bfg atko i am about to out on it, need get with one of the writers at my part time job to find me a couple more, bfg discontinued the load range d ko and as far as i can tell arent making the ko2 in lrd and i really dont want e load range tires..... But i get a hefty discount on certain tires at my part time job, so.....
#30
Stock aluminum driveshaft will vibrate above 95-100mph and not rated for speeds that high. They are known to explode above those speeds. There is a reason they set the factory limiter to 98 mph.
I'd go with a built steel shaft. And the front driveshaft should be a steel unit and I haven't heard of any problems with those ever.
Also, I would NOT select a steel shaft in this long of an application. One easy way to lower critical speed is to increase mass.
You'd get further in life if you knew when to shut your pie hole and listen.
