Need help identifying noise when braking
Old 09-19-2014, 04:32 PM
KHester84's Avatar
Default Need help identifying noise when braking
Hey guys I've been noticing my truck making a creaking noise when I hit the brakes, does it really bad when its not fully warmed up. I've pulled the left front wheel off and can't see anything loose or about to break, need to ideas on what to check.
As you can tell it sounds like it is related to a specific wheel position as it spins, it always does it in that manner. My steering wheel does shake when I press the brakes, so I know I need a brake job. My pads have life left, and the rotors aren't in too bad of shape.
2008 Silverado brake noise - YouTube
Old 09-19-2014, 04:39 PM
GMC93's Avatar
Wheel bearings if i had to guess.
Old 09-19-2014, 05:35 PM
Jason Z69's Avatar
I would say bearings too. It could be the warped rotor pushing on the break caliper. How many miles on the bearings. Also look at your wheel for hair line cracks.
Old 09-25-2014, 09:38 AM
KHester84's Avatar
I had that wheel bearing replaced at about 75k, it has 115k now so not that much...maybe just got a bad batch of bearings. I'll check the wheel out too, didn't really notice it until I swapped rims so maybe thats the culprit!
Old 09-25-2014, 10:04 AM
Jason Z69's Avatar
Did u have aftermarket rims before? If so did u take the caliper lock rings off the studs?
Old 09-25-2014, 10:09 AM
KHester84's Avatar
No I had oem rims before...not sure I follow what you're asking.
Old 09-25-2014, 03:00 PM
Jason Z69's Avatar
Ther is some lock rings on the lug nut studs. If u dont take them off it can throw a light, make noises, and cause the brakes to pulse. Ithink they have 3 per wheel. Pull off 1 wheel and look. U should see them unless they have already been taken off. They r usually a brass looking ring. Smooth on the outside and have teeth on the inside. It dont hurt to break them to get them off. Wish i had a picture to show u. I think u will see them if they r still on the truck.
Old 09-25-2014, 03:02 PM
KHester84's Avatar
Hmm...I've never seen those before. You trolling me? lol
Old 09-25-2014, 03:05 PM
Jason Z69's Avatar
No sir. I did it befor when i put my first set of wheels on my truck. I didnt know they needed to be taken off.
Old 09-25-2014, 03:17 PM
Jason Z69's Avatar
I found another forum thats talking about it. Its tahoukonforum.com typ in weird front end sound after installing 24" kmc slides. Its about 15 posts down.
Quick Reply: Need help identifying noise when braking
