Moog Offset bushings
Has anyone dealt with this bushings? I have an 03 ecsb 2" drop spindles up front and just replaced upper and lower control arms with moog upper and lower control arms rather than just replacing ball joints and bushings. The bushings i got in the uppers are the offset bushings to give more adjustment with the camber and caster. They way they came was with the arrows pointing out and the alignment shop cant get me anymore negative camber im sitting at 1degree positive on driver side and 1.3 degree positive on passenger side. Do the bushings need to be taken out and repressed in with teh arrows pointing toward the frame to get the extra negative camber i need to get the alignment right? Any info would be much appreciated.
