How Hard To Replace CV Joint??? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 02-04-2005, 11:21 PM   #1
GH1086's Avatar
Default How Hard To Replace CV Joint???
I have a 2000 Chevy Silverado 2500 with the 6.0 engine, my passenger side CV joint is going bad as well as the boot, is it difficult to change? and also can anybody give me a step by step on how to do it?
GH1086 is offline   Reply With Quote
Old 02-05-2005, 12:15 AM   #2
1. get service or repair manual. (torque spec's and pictures)
2. remove 6 inner joint flange bolts. Rotate wheel to get top three.
3. remove wheel
4. remove sway bar link
5. remove axle hub nut dust cover on hub, should be zinc plated(gold colored)
6. remove big axle hub nut.
7. use dead blow to help slide axle out of the spline hub.
8. reverse process for assembly, using manual for torque spec's for the bolts. axle hub nut torque spec is important!!!!!! Should take a newb about 45 mins. A guy who has done it a few times, about 25min.
8100hammer is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Cleaned MAF, ping went away...for a day lucas287 Tuning, Diagnostics, Electronics, and Wiring 25 03-25-2017 09:53 AM
Electrical Issues Idryfly5 GMT 900 Trucks General Discussion 1 09-02-2015 12:06 AM
Need HELP Figuring Out Part-Throttle Detonation/Ping 6.0 Silverado 2000 Fast86z GM Engine & Exhaust Performance 4 08-23-2015 12:35 AM
03 ECSB Custom T56 Swap Ketis Trucks and SUV Classifieds 6 07-23-2015 12:37 PM
Tags
01, 2000, 2500, 4x4, axle, chevrolet, chevy, cv, joint, joints, replace, replacing, servicing, silverado, torque
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
