Here we go JakesPerformance 4l80E/Transbrake
Old 05-13-2011, 12:36 AM
  #31
foose04's Avatar
Nope trans never would hold on lockup... It work for light throttle, but any higher it push thru the rpms.. Would this cause it to slip in every gear though?
Old 05-13-2011, 11:27 AM
  #32
Hunt&Fisherator
silver-mod-o's Avatar
thats one way I test for a slipping clutch/trans... manually lock the converter in whatever gear is suspect and roll in the throttle... should accellerate like a manual trans vehicle. no converter stall/flare is there to be misleading. if your RPM is rising faster than youre gaining speed then youve got an issue... its usually more apparent and easier to pinpoint in the higher gears where load is higher.
Old 05-15-2011, 02:47 PM
  #33
built408's Avatar
No seal on the input shaft was definitely the culprit.
sguiffre13
08-20-2015 06:54 PM
sguiffre13
12-07-2014 02:07 PM
lsxperformance
06-04-2014 09:25 PM
foose04
63
03-06-2013 07:32 PM
Quick Reply: Here we go JakesPerformance 4l80E/Transbrake
