Guys Running Detroit Tru Trac Come In..
Old 10-25-2008, 01:02 PM
chevrolade's Avatar
so if its a limited slip unit,its still going to take off with power to one tire??excuse my nooobness
Old 10-25-2008, 01:34 PM
1989k1500's Avatar
Its not an open diff. It will still put power to both tires. But it wont be quite as good as a locker.
A friend of mine had a true trac in his truck and right after he put it in I wanted to see how well it help posi. I have 8 minutes of video where hes spinning the tires the entire time. One time it swung around so hard it lifted on tire off and still never unlocked.
Old 10-25-2008, 01:39 PM
chevrolade's Avatar
Nice Man,thanks For The Info Guys.IM GOING TO ORDER ONE,ONE MORE THING ITS GOING TO BE FOR A 8.5/6 10BOLT
28 OR 30 SPLINE??
Old 10-25-2008, 01:57 PM
TurboGibbs's Avatar
I love mine for the street and works very well in most drag applications. I have approx. 50k miles on it now. I did have one problem with mine though.
The bolts on each end cap that hold the unit together backed out. When I was driving, I began to have a huge jerk like I hit a hellacious pot hole but there wasn't any of course. After 3 or 4 times of this happening, I took the rear cover off to find all the bolts to have begun to back out or have been sheered by hitting the housing when they backed out. The unit was being held together by the bearings and the housing its self.
I attribute the problem due to several 5000+ clutch dumps on slicks with a few of them being on a 150 shot. It takes 2-3x's the torque from an automatic to put the same kinds of loads on a rear end as a manual does dead hooking. Heck, I snapped an axle and Parish8 never even did that with stock axles.
Basically, the worm gear design pushes outwards on the end caps during heavy loads and probably stretched the bolts. I replaced the bolts with new grade 8's and red loctite. I have had no issues in 20k miles but I haven't put slicks on it again either.
So my opinon, if you are running an automatic, beat the hell out of it. If you have a manual, be careful with the hard launches at the track on stickies.
Old 10-25-2008, 02:02 PM
KySilverado's Avatar
about a year now. with synthetic. no problems. performs well.
Old 10-25-2008, 02:31 PM
WorkTruc's Avatar
About 2 years now and still performs perfectly
Old 10-26-2008, 09:59 AM
TXsilverado's Avatar
what everyone else said....q34
Old 10-26-2008, 10:40 AM
Moddoo's Avatar
I have had some weird symptoms since I installed mine.
It just seems like I get a lot of traction all the time no matter what I'm doing
Even with the g-80 working like it should, this hooks way better.
LOL
It's pretty surprising how it just seems to work great always.
Old 10-27-2008, 11:36 AM
Doobie's Avatar
8 months with mine now and works flawlessly. I'm using non-synthetic gear lube as recommended.
Old 10-27-2008, 09:07 PM
Laid Back
Beatdown Z's Avatar
$350 with free shipping, there's only one left:
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Quick Reply: Guys Running Detroit Tru Trac Come In..
