front suspension rebuild
my 05 sierra has a 3/5 drop and 20" rims and i believe after 12 years the front suspension is shot. both front tires wore out on the inside and the ride felt bumpy even on a smooth surface. i got new tires and it still rides the same. I think everything is just worn out. anyone done this ? is there something i can get while I'm there that is better than oem stuff?
Stick with Moog parts. Get the upper/lower arms. It'll save you a ton of headache.
If you're sticking with the oem swaybar, get poly bushings for the mounts and endlinks.
1. LCAs
2. UCAs
3. 2 - outer tie rod ends
4. End links (your choice on OEM or poly, poly does make a difference)
5. Sway bar mount bushings (under the core support)
6. 2 Wheel bearing assemblies (they are different for 16 and 17in wheels. I know you have 20s but what did your truck come with?)
That's the hardware. If you want to do the brakes while you have it apart, now would be a good time. Rotors, pads, calipers, lines, etc. is what you would need.
After having my front end drop changed out 2x now, it is MUCH easier to just get the LCAs with the ball joints/bushings already in and ready to go. You have to ask yourself, "how much is my time worth"? For me, it's worth just spending the $190 or so for the pair of LCAs rather than beat the balljoints out and have to fool with the bushings to.
10 Second Truck Club
Heres another list.
UCA
LCA >these two take care of balljoints & bushings
Inner tie rods
Outer tie rods
Sway bar endlinks
Sway bar bushings for the swaybar to frame mounts
Shocks, good ones, makes a world of difference
Wheel bearing assemblies if yours are bad or while your there lol
05+ trucks came with the 17" wheels front and drums out back which means you already have the larger brakes.
Moog usually has everything for these trucks front suspension wise and thats what i use on my trucks.
UCA
Inner tie rods
Outer tie rods
Sway bar endlinks
Heres another list.
UCA
Inner tie rods
Outer tie rods
Sway bar endlinks
UCA
Inner tie rods
Outer tie rods
Sway bar endlinks
10 Second Club
I redid mine around tax time this year. I used Moog lower arms, dorman uppers, I think - rare parts? Tie rod ends and sway bar end links. And I used belltech Street Performance shocks. (I also cut half a coil off some lower mile springs at the same time) It was a night and day difference.
