Ford 9" vs. 9.5" 14 bolt from a strength perspective
Ok, you need one rear end that you can depend on isn't going to break at the track, 14 bolt or 9"? Specifically, 14 bolt with Trutrac LSD vs Strange pro nodular iron with S-trac. Which is more parasitic?
From a cost perspective, both are actually looking pretty similar....
The biggest advantage to the 9" I see is that the center section is completely removable and can be serviced on a work bench. You can also have 2 separate center sections, one for street driving and one for track with a very aggressive gear set and spool
Resident Retard
Like i asked i think the strength comes from the pinion placement or it has another bearing which adds to support. I could have swore i read that somewhere. I might be wrong thou.
Btw have you ever lifted. 9in center section? They are definitely on the heavy side. Like pop a ******** heavy.
