eliminating certain check balls on the 4l60e transmission
eliminating certain check ***** on the 4l60e transmission
hey guys, So I managed to finally get my hands on a donor trans for parts. and I was going over it and comparing it to my current trans.
from it looks like, I'll be eliminating the two check ***** housed inside the case and I'm considering removing the one inside the input shaft. from what I've been reading(and from what I understand) removing the one in the input shaft will speed up the engagement of the TCC(firmer engagement).
So, from what I can tell, and correct me if I'm wrong, by eliminating those three check *****, I should get a firmer low/reverse, 3-4?, and TCC engagement.
The forward check ball in my 99 trans was already eliminated by whoever rebuilt it the first time.
now the only thing I'm questioning is whether or not to do the aluminum accumulator pistons. I'm not really sure what it would bring to the table. other than a reduced risk or cracking.
Don't eliminate any check *****. You modify the hole feed size. Dont take the input shaft checkball out either. It will make it engage too harsh, it will lessen the longevity of the converter, or damage it, and put more strain on the input shaft. Either put a transgo valve in the VB or set the Converter on pressures to max.
Laid Back
X2 What megabuddys said. You could remove the checkball from the capsule for the low/reverse piston if you want. Leave the input shaft checkball alone and make sure the 3rd accumulator checkball capsule doesn't leak.
For an improved 3-4 shift, block the 4th accumulator feed hole in the case.
