Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM Drivetrain & Suspension
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 10-25-2006, 09:39 AM   #1
Trader Rating: 34
dirt track racer 81's Avatar
Send a message via Yahoo to dirt track racer 81
Default difference between 700r4 and 4l60e Converter
whats the differnce between the 700r4 converter and 4l60e converter?
__________________
-Tyler
2000 White ECSB-370-L92 heads-Vic Jr-FAST 4150-NOS Crossbar Nitrous Plate- 10.64 @ 128 1.61 60'Balancer Install Tool!!==>>> http://sdparts.com/details/scoggin-d...-center/sd6628
dirt track racer 81 is offline   Reply With Quote
Old 10-25-2006, 09:42 AM   #2
Trader Rating: 31
11 Second Truck Club
bluecajun5.3's Avatar
Send a message via AIM to bluecajun5.3
input splines that's for sure. electronics.
__________________
11 Sierra NHT 6.2
13.92@99 Tuned
89 Mustang LSX 6.0
10.35@130 pump gas LQ4
Knothead Racing
bluecajun5.3 is offline   Reply With Quote
Old 10-25-2006, 12:48 PM   #3
Trader Rating: 0
Gran Patron's Avatar
They are both different in design. They wont directly interchange,from what I've read before.
__________________
http://i2.photobucket.com/albums/y48/runin9s/454sig.jpg
96.RCSSB 5.0L, LSX Future Planned.
03.RCSSB.5.3.3:73.G80 SOLD!
Gran Patron is offline   Reply With Quote
Old 10-25-2006, 01:04 PM   #4
Trader Rating: 3
Moderately Differentiated
dewmanshu's Avatar
Send a message via AIM to dewmanshu
The only real difference is the name. A 4L60 is a 700-R4. The name only changed to better identify the transmission. The four meaning it has four gears (1-3 plus overdrive). The "L" for longitudaly mounted (as compared to Transverse on a FWD car). "60" is the relative torque value. For example, 80 is stronger than 60, which is stronger than 40, etc... A 4L80-E can handle more torque than a 4L60-E. The "E" you are seeing in the last sentence denotes it is electronically shifted by a computer.
I just copied and pasted. Discuss.
__________________
2K Silverado 4WD/6.0/80E/TVS1900/Juiced at the track (Internet Crap) Tuned by the Seat of My Pants
12.22 @ 110.75 blower/meth/110 (76*) (radix)
12.130 @ 109.95 blower (45*) (TVS1900)
11.66 @ 115.95 bower/meth/110/50shot (45*) (radix)
11.35 @ 117.35 blower/meth/110/75shot (45*) (radix)
dewmanshu is offline   Reply With Quote
Old 10-25-2006, 01:06 PM   #5
Trader Rating: 3
dewmanshu's Avatar
Quote:
I think your thinkin gof the thm700
Quote:
700R4 / 4L60
At approximately the same time as the 200-4R's release, the Hydramatic 700R4 was introduced 1982 for use in Chevrolet/GMC vehicles.
The gearing for the 700 is (commonly rounded off to 3.06, 1.63, 1.00, 0.70, and 2.29):
  • First - 3.059
  • Second - 1.625
  • Third - 1.000
  • Fourth - 0.696
  • Reverse - 2.294
Initially, the 700R4 was not considered a strong transmission, since the torque of a 350 in³ V8 would lead to transmission failure. The original version of the transmission had a 27 spline input shaft - this was but one of many possible and common failure points with the early transmission. However, the design was continually refined and upgraded, and in 1987, the 700 was used behind a 350 small block V8 (from IROC-Z Camaros to pickup trucks).
Around 1984, 700R4s designed for use behind Chevrolet small block V8s received a 30 spline input shaft which used a different torque converter than its 2.8 V6 and 2.2 L4 powerplants. Between 1984 - 1987, internal components, from the ring gear to the oil pump housing, were updated, ending with the auxillary valve body (for 700s manufactured after October 1986).
Without pictures, the 700 can be identified by the oilpan having a rectangular shape being longer front-to-rear than side-to-side and held to the transmission by 16 bolts, 3 bolts front, 3 bolts rear, 5 bolts left side, and 5 bolts right side.
The tailshaft housing is held onto the main case by 4 bolts (the bolt spacing is similar to the THM350), and uses a square-cut o-ring seal, and not a gasket. The typical width of this transmission where it bolts to the engine is 20 inches (510 mm) overall. From the engine/trans mating surface to the crossmember mount bolt is 22-1/2 inches (570 mm), and engine/trans surface to output shaft housing mating surface is 23-3/8 inches (594 mm) overall, with the tailshaft housing typically measuring 7-5/8 inches (194 mm).
Transmission fluid cooler lines: on the 700R4 the bottom fitting on the right side of the transmission is the "out" line to the cooler and the top fitting is for the return line from the cooler. These fittings are 1/4-inch pipe thread, and CAN include an adapter from the factory for threaded steel lines in an SAE size. 4L60Es manufactured after 1995 use the modern-day snap-in connections as opposed to threaded SAE fittings.
4L60
The 700 was renamed the 4L60, when the electronic version, 4L60-E, was phased in (1993 for GM trucks, vans, and SUVs, and 1994 for RWD passenger cars). Around 1996, a bolt-on bellhousing was phased in (along with a six-bolt tailhousing) when the transmission was bolted behind an inline four cylinder or the Vortec engine family.
__________________
Old 10-25-2006, 01:10 PM   #6
Trader Rating: 3
dewmanshu's Avatar
Quote:
The 4L60-E (and similar 4L65-E) is a series of automatic transmissions from General Motors. Designed for longitudinal engine configurations, the series includes 4 forward gears. It is an evolution of the Turbo-Hydramatic 700R4, originally produced in 1982.
The 4L60-E and 4L65-E are built at Toledo Transmission in Toledo, Ohio and have also been built at Romulus Transmission in Romulus, Michigan and Ramos Arizpe, Mexico.
The two transmissions are differentiated mainly by the number of pinion gears in their planetary gearsets: The 4L60-E has four, while the heavy-duty 4L65-E has five. Other elements of the 4L60-E design were strengthened when the 4L65-E was introduced, but these were incorporated into the 4L60-E in 2002.
Gear ratios:
1234R3.061.631.000.702.29
4L60-E
The THM700 was renamed "4L60" (RPO M30) following the new General Motors naming convention, when the electronic version, 4L60-E, was phased in. This happened in 1993 for trucks, vans, and SUVs, and 1994 for rear wheel drive passenger cars. Around 1996, a bolt-on bellhousing was phased in (along with a six-bolt tailhousing) when the transmission was bolted behind an inline four cylinder or the Vortec engine family.
The 4L60-E is rated to handle up to 360 ft·lbf (488 N·m) of torque.
Applications:4L65-E
An updated 4L60-E, the 4L65-E (RPO M32), was phased in around the 2003 model year when coupled behind the 6.0 Vortec. Five-pinion planetaries, along with a modified drum/input shaft assembly, were improved to withstand up to 380 ft·lbf (515 N·m) of torque.
Applications:
I was just researching this stuff the other day...been tuning shift points and pressures. Already had this saved in favorites. Quick grab for ya.
__________________
Old 10-25-2006, 04:40 PM   #7
Trader Rating: 7
Banned
Quik's Avatar
Send a message via AIM to Quik
im not reading half that crap
the first series of 60es could use a 7000r4 conveter... i have first hand experience as in the pinks car
Quik is offline   Reply With Quote
Old 10-25-2006, 04:51 PM   #8
Trader Rating: 3
dewmanshu's Avatar
well, half is better than nothing if you were interested. Just info dude, nothing to get all excited about. unfortunately were all not blessed with pink experience.
__________________
Old 10-25-2006, 09:50 PM   #9
Trader Rating: 10
nonnieselman's Avatar
Send a message via AIM to nonnieselman
BELIEVE ME.... THE 700R4 VERTER WONT FIT ON THE 4L60E TRANNYS.. AND THEN THERE ARE 2 DIFFERENT 4L60Es.
thats whats holding me back right now..
there is a 298mm input shaft or pump shaft? and there is the 300mm shaft.
i think thats what lilreddevil told me,
but i got all the right stuff now, except the TC bolts.
__________________
-Jonathan
2000 ECSB Silverado-LQ4/Isky 215/4L80E/KBRacing S475
13.9@104 5psi
12.9@113 ~ 5-25psi on cooper AT3's
Oil Filter Part Numbers
NGK Spark Plug Info
4L60E-4L80E Wiring Swap
GM Fluid Capacities
What Gear Ratios Do I Have?
nonnieselman is offline   Reply With Quote
Old 10-25-2006, 10:17 PM   #10
Trader Rating: 34
reason why i posted this..my boss wantin to put my torque converter that i had in his 700r4 tranny and was just tryin to find out for sure on this..i didnt think it would work
__________________
-Tyler
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
2010, 298mm, 300mm, 4l60, 4l60e, 7000r4, 700r4, canyon, difference, differences, output, pump, splines, tuning, whats
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
