4L80 swap blowing fuses
Old 03-26-2012, 06:09 AM
slowec's Avatar
Default 4L80 swap blowing fuses
I swapped a 4l80 in a 99 truck for a friend and the " ing 0 " fuse blows now. traced it down to circuit 1020, a pink power feed that goes to a few solenods in the transmission. Any tranmission "yodas" want to tell me what to look for?
...Please...
Old 03-26-2012, 08:05 AM
nonnieselman's Avatar
Might wanna check the connector.
Unplug the round connector off the trans and see if it still blows it.
If it does then you got a problem in the wiring.
If it doesnt, then maybe a bad 'noid? Or wiring inside the trans?
Old 03-26-2012, 08:12 AM
slowec's Avatar
Unpug the main connector, no blow
back out 1020 pink wire, no blow
Just wondering if there were any common shorts to look for, I know I need to drop the pan and inpect.
Old 03-26-2012, 10:24 AM
JoeyGC5's Avatar
I found someone left the harness loose on a junkyard purchased 4l80e and pinched 1/2 the wires by the pan once
Old 03-27-2012, 06:26 AM
slowec's Avatar
Now the really awful part. Dropped the pan to test and inspect... Wires look good, solenoids have resistance reading . (not shorted) and the fuse is not popping with ignition on anymore. Gotta love intermittent electrical issues!
Old 03-28-2012, 06:31 AM
slowec's Avatar
Seeing as how this is turning into a blog instead of a thread, I'll continue. I ordered all the componets on that circuit. new harness, tcc solenoid and both shift solenoids. We will see where that gets me...
Bluecollar Hotrods
03-13-2017 05:02 PM
colekill
14
10-11-2016 11:56 PM
GM-only
07-19-2015 10:48 PM
GreyChevy
07-07-2015 08:57 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: 4L80 swap blowing fuses
