Converter question
Old 04-26-2008, 08:57 AM
1BAD73's Avatar
Default Converter question
Last week I installed a used TCI 3500 converter in my 00 RCSB. The truck has 140,000 miles and the trans is otherwise bone stock. The converter worked ok for the first 250 miles, the only problem it had was it would vibrate/slightly grind when locking up. Yesterday the converter decided not to lock up at all. My trucks message center went red and said Trans hot... idle truck. When I installed the converter, I put a large tranny cooler in front of the radiator. My questions are: Which tranny cooler line does everyone tie into for their aftermarket coolers : top or bottom?
Do you think the converter is junk?
Is this the problem everyone else has had with the lockup on TCI converters?
Your help is much appreciated.
Old 04-26-2008, 09:31 AM
Wearin' da big hat
00ChevyScott's Avatar
Converter is probably junk, alot of people have problems with TCI man.
Get a yank or Vig
Old 04-26-2008, 10:29 AM
1989k1500's Avatar
Yea everyone seems to have problems with TCI convertors not locking up.
Its also not good that you put that big *** stall in there with no shift kit or anything.
Edit: You also need to get the truck tuned for the converter.
Old 04-26-2008, 10:45 AM
Truckshop's Avatar
get it tuned so it will lock up properly then it should quit overheating.
Old 04-26-2008, 11:38 AM
Banned
Klive's Avatar
definatly suspect that the TCI has taken a dump....
Old 04-26-2008, 12:24 PM
built408's Avatar
TCI's are junk.
Old 04-26-2008, 07:51 PM
Wide Open's Avatar
I destroyed a 10" TCI converter and several supposedly street/strip built transmissions with a 406 SBC. I don't think I would buy another TCI product. Other than their aluminum deep pan which I like ok.
Old 04-26-2008, 08:08 PM
Baltimore Whore
Mangled03gmc's Avatar
TCI verters don't seem to do well in the 4l60's for some reason, I would try to find a Yank PI or older fuddle....
John
Old 04-26-2008, 08:20 PM
Banned
yea get a pi and also a deep pan
GXPJAY
02-13-2022 08:15 AM
Jblake
08-17-2015 12:59 PM
USMCvet0311
08-01-2015 07:45 AM
WICK3DxGATA
07-21-2015 06:59 PM
grantpo
07-15-2015 12:21 PM
Quick Reply: Converter question
