99 GMC Sierra 4l60e removal, need some help!
#24
Finally got the thing off and to the rebuild shop. I just got a pry bar between the engine and trans case and hammered away. Popped right off.
Now onto a couple questions. Is there a "how to" on the install somewhere with torque specs on these bolts or is it just run them in with an impact situation?
Can I replace those torque converter bolts with grade 8 bolts from lowes with the same thread and length? or do they need to be a speicial type?
#25
Get converter bolts from dealer they are maybe $6-7 a piece... Unless you are getting a converter from circle d or whatever then they should come with bolts.... Technically there are torque specs on everything but run them in until you acheive goodentite, and youll be fine....
#28
#30
Awesome guys thanks. I'll give the dealer a call and grab those.
Now how about cleaning the trans cooler and lines. I broke the shell so i'm not sure how much metal might be floating around in there. when I dropped the pan to drain it there was nothing crazy in there but it was metallic.
