99 3/4 ton 4wd rear axle in 04 1/2 ton 2wd?
Old 02-13-2017, 12:01 PM
stroker87's Avatar
Default 99 3/4 ton 4wd rear axle in 04 1/2 ton 2wd?
my truck is a 1 wheel wonder 10 bolt a local guy is selling a rear axle from a 99 3/4 ton truck 3.73 G80 14 bolt, my truck is a 04 1/2 ton 2wd
simple swap or?
Old 02-15-2017, 05:01 AM
1bad2k's Avatar
You would definitely need 6 lug axles, also need to measure wms to wms on each axle (I believe they are different) and more importantly you need to make sure the spring perches have the same distance between them.
Old 02-15-2017, 08:52 AM
stroker87's Avatar
I know axles for sure every thing else is what i'm wondering about? hes about 100 miles from me so probably just going to pass on it
Old 02-17-2017, 01:39 AM
Custm2500's Rude Friend
1FastBrick's Avatar
It's a bolt in, however it requires some custom work to make it 6 lug and use the 1500 series brakes. Axles are off the shelf replacements.
https://www.performancetrucks.net/fo...ctures-477641/
