99-07 4WD Front Coilover Conversion
#253
Just a reminder, I still have a set of Atomic's lower conversion brackets, along with everything else to do the swap that I want to sell CHEAP. I never installed anything, and I'm selling my Escalade, but I'm way past the window to return to Summit, so if you're interested, PM me and I'll send you a list of all the parts I have, the short version is that I was going for a 3/5+ lowering with the stud top shock mounts, have the correct length QA1 shocks for the back as well as a bag over axle setup (bags and brackets) for the SUV rear end. I've even got the torsion bar tool I can throw in.
#254
Has anyone used QA1 coilovers in conjunction with 2" spindles to get the equivalent of a 2wd 4/6 drop? I know 4wd guys sometime say what drop they have but that is from 4wd height. I want my torsion bar truck to be as low as a 4/6 2wd truck. I've seen guys use the DS301 but it almost seems too low of you were to add a 2" drop spindle. I know there are quite a few options for the shock whether it's eyelet with your mount, procomp adapter, stud top adapter with upgraded bushing, etc... Any input or am I stuck lowering the truck first to measure the shock? I didn't really want to lower the truck on torsion bars, but I might have to
#255
If you look at my PDF and go to page 13 it has pictures of what you need to measure, http://atomicfabandperformance.com/w...lovers_v20.pdf
If you can get that measurement at your current ride height as it sits now on the ground and tell me how much lower you want to go I can figure out what combination of stuff you need. And yea several guys have used my brackets in conjunction with drop spindles for more drop.
#257
I have the ds301s and am going to be putting Belltech spindles on in a couple of weeks. What exactly are you wanting to know?
#258
I would just like to have a certain ride height for my truck but I have to choose the right coilover. It's tough since getting it wrong means I could lower the jack and the truck is too slammed to drive. Based on the required travel of these shocks, you can't just pre-load it up and get height adjustment, so you need to make sure you're dead nuts on.
I want my truck to look like this with 2" spindles and coilovers only, so I'm curious how yours looks
#260
It's not quite as low as the photo you posted, I'd say 1-1.5" higher. To get as low as you want, you'd have to use the DS301 for sure.
