4wd won't engage - light keeps blinking - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 08-11-2007, 03:10 PM   #1
High on diesel fumes
thunder550's Avatar
Default 4wd won't engage - light keeps blinking
Having some trouble with 4wd. When I hit any of the buttons besides 2hi, the light just flashes continuously and will never engage. I don't have the "service 4wd" light illuminated on the dash, and otherwise the switch looks like it's acting normal. Any ideas? It's Autotrac, in case that makes a difference.
thunder550 is offline   Reply With Quote
Old 08-11-2007, 03:16 PM   #2
Grumpy5.3's Avatar
can you pull codes from your transfer case control module??? It sounds like the encoder motor sensor or the shift module...idk
Grumpy5.3 is offline   Reply With Quote
Old 08-11-2007, 03:18 PM   #3
thunder550's Avatar
I'll get back out there in a minute and see if I can pull any codes. I'm chillin on my American Standard right now
Old 08-11-2007, 03:23 PM   #4
thunder550's Avatar
Nope, no codes in the PCM.
Old 08-11-2007, 03:25 PM   #5
Ive had that problem a couple times before without the check 4wd light and a couple with it on. I took it to the dealer and they said they had to reflash the computer, and the other time they replaced a solenoid that went bad.
dirtdudeaz is offline   Reply With Quote
Old 08-11-2007, 03:26 PM   #6
Grumpy5.3's Avatar
I bet you have some in the transfer case control module. You know anyone with a scan tool that can check those codes???
Old 08-11-2007, 10:10 PM   #7
thunder550's Avatar
Is that different than a normal scan tool? I have EFILive to scan the PCM, not sure if I can get to the t-case module with that?
Old 08-11-2007, 11:22 PM   #8
Grumpy5.3's Avatar
Quote:
yes its different, you need to find a scan tool that will check the 4x4 system. I bet you have a C0327.
Old 08-13-2007, 04:49 AM   #9
thunder550's Avatar
Question - would low fluid in the front diff cause something like this?
Old 08-13-2007, 10:03 AM   #10
Grumpy5.3's Avatar
Ummmm, its not good, but I doubt it causes your problem. I am betting its your encoder motor sensor... but without pulling codes your kindof in the dark...
Thread Thread Starter Forum Replies Last Post
XS-Power Longtube Header Systems SALE! Superman09 Sponsor's Announcements, Sales, and Specials 9 09-25-2015 06:55 AM
Yank 3600 06 4.8 GM Parts Classifieds 5 09-11-2015 11:36 AM
08 Chevy Avy 5.3L DoD issue? Am I good now? MA$TER_E Tuning, Diagnostics, Electronics, and Wiring 5 09-09-2015 04:14 PM
Electrical Issues Idryfly5 GMT 900 Trucks General Discussion 1 09-02-2015 01:06 AM
Tags
06, 2005, 2007, 4wd, c0323, dtc, duramax, engage, gm, hi2, hi4, lo4, lt, p0502, trailblazer
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
