4l80e AN transmission fitting
Old 08-29-2014, 09:15 AM
boost27's Avatar
Default 4l80e AN transmission fitting
I looking for a fitting for my transmission 1/4 NPSM to -6AN 90. I have a straight, trying to run my transmission line but I can get a 90 hose on because of the trans tunnel. 4l80e shoehorned 1gen jimmy.
Old 08-30-2014, 12:35 AM
8 Second Truck Club
Blown06's Avatar
Might give any of the sponsor transmission guys a call. They will have what you need. I got mine from FLT.
Remember the rear fitting is special and uses an extension off the fitting inside the trans. Would hate to see you burn your **** up.
Old 08-30-2014, 11:38 AM
oakley6575's Avatar
Depends on what core is used. 1997 and later use that fitting you are talking about since they moved the rear cooler port further back in the case for center lubrication. You don't use that fitting if you have the 1991-1996.
Old 09-01-2014, 10:29 PM
BMF
Razor's Avatar
-6AN 4L80E GM transmission cooler fittings - Sweet Performance Products, Inc - (Powered by CubeCart)
Old 09-01-2014, 11:09 PM
gmc6.0's Avatar
That's where I got mine from
Old 09-01-2014, 11:12 PM
BMF
Razor's Avatar
Me too. Work great.
OP, might have to drop the transmission down to install the lines.
OR,
BFH tunnel clearance.
Old 09-02-2014, 01:14 AM
smoggist's Avatar
I believe tci also makes the same style of fittings. That's what im using anyway. Can't think of the part # off the top of my head tho.
Old 09-20-2014, 09:06 AM
boost27's Avatar
I found some low profile ons on ebay. Bango fittings and they worked out great http://i.ebayimg.com/00/s/MTYwMFgxNjAw/z/v54AAOSwbqpTw3HI/$_35.JPG
Oobray
06-13-2022 03:38 AM
XL7
05-05-2022 01:48 PM
5.3Okasai
03-09-2022 01:07 PM
Go5.3tt06
09-12-2015 09:29 AM
Ammadien
07-22-2015 08:50 PM
Quick Reply: 4l80e AN transmission fitting
