Camburg chevy/gmc 1500 2wd 99-06 performance 6.5 kit
Old 03-12-2021, 10:28 PM
Jseal52's Avatar
Default Camburg chevy/gmc 1500 2wd 99-06 performance 6.5 kit
I知 looking into getting a prerunner setup for my truck. Truck is a 2003 2wd rcsb and I知 looking at the camburg mid travel.
https://camburg.com/shop/suspension/...mance-6-5-kit/
just wondering if anyone has used one and how it worked out. Also what should be do to the rear suspension.
I want to try to run a coilover and wondering if the 07+ coilover will fit in the 2003 location with some sorta kit? Any help would be great.
Old 03-13-2021, 02:33 PM
tjmath's Avatar
It all really depends on what you want to do with the truck. As far as using 07+ struts in the 03 I do not think they will fit, and I would definitely recommend having coilovers spec'd for the application.
Camburg makes good stuff, but if you're really gonna use and abuse it I would get the Dirt King kit.
https://dirtkingfabrication.com/coll...-kit-dk-632909
Having the fabricated lower gives you a lot of room to grow as well. You can start with a single coilover and add a bypass down the road if you start to outgrow the single coilover.
For the rear your best option would be a bed cage with through bed shocks and deavers.
Old 03-13-2021, 04:10 PM
Jseal52's Avatar
I think the plan is to start small and get my feet wet. A buddy of mine is selling his mid travel kit from camburg.
So go with the mid travel and try to put a coilover in the mid travel kit and then get a deaver kit with shackles and hangers and use factory shock location.
I think that would be a good start and then I can do some more extreme mods down the road when I know more about the prerunner stuff.
Bigblu
11-23-2016 09:45 AM
badream
12-20-2014 12:26 AM
Blown06
01-14-2012 12:51 AM
Quick Reply: Camburg chevy/gmc 1500 2wd 99-06 performance 6.5 kit
