4l80e 4x4 swap- Driveshaft question
Old 02-20-2014, 02:34 PM
nickleahy23's Avatar
Default 4l80e 4x4 swap- Driveshaft question
Just got a question for you 4x4 4l80e swap guys. I know the 4l80e is 1 11/16" longer (thanks Atomic) than a 4l60e. What did you do for the front shaft? The only guy i can find decent around me will shorten and balance the rear for $80 bucks. For the front though, he wants 2-300 since he does a whole new tube and everything or i can get one custom made, for even more. Any other options out there that are cheaper? If i remember right, on my tahoe the yoke is almost all of the way into the t-case, leaving about 5-6" of spline contact. would you be alright losing some of that any not lengthening it? considering the front diff and t case stay mostly stationary?
Old 02-20-2014, 02:48 PM
Vortec350ss's Avatar
Pat (03SierraSLT) started a thread that identified different drive shaft specifics.
Old 02-20-2014, 02:52 PM
timmay208's Avatar
GM PN 15182094
i got mine out of a 05 GM truck with 8.1 and allison from here
02 03 04 05 06 07 08 09 10 Silverado 2500 Front Drive Shaft at 6 SPD 007061 | eBay
i found tons on ebay with that PN, another guy on the forum got the same PN drive shaft from a 04 truck with a 6.0 in it
Old 02-20-2014, 03:08 PM
03sierraslt's Avatar
The part number listed above.
Old 02-20-2014, 03:15 PM
sweet, so the 2500 drive shaft has the correct splines for my tcase and ujoint for the front diff? that makes it easy my buddy has one laying at his house.
Old 02-20-2014, 03:26 PM
Yep and yep.
Here is mine.
Old 02-20-2014, 03:29 PM
Good deal! Thanks for the help.
Old 02-20-2014, 05:45 PM
Ok so your sayin this front driveshaft is a direct bolt in for the 80e swap? I got one from a 2500 and it's 2'' too short.
Old 02-20-2014, 06:12 PM
I have a gauge for that
Atomic's Avatar
I cut off my yokes and sent them to driveshaft specialist in texas and im pretty sure a new .125" wall shaft was less than $300.
Old 02-20-2014, 06:13 PM
timmay208's Avatar
what tcase do you have? what was the PN on your driveshaft? cause one from the duramax will not work its to short
Quick Reply: 4l80e 4x4 swap- Driveshaft question
