4L60E to 4L80E swap on a RCSB, driveshaft question
Old 06-22-2011, 01:49 PM
N20GMC's Avatar
This is the slip yoke you need. And I will pm you.
http://cgi.ebay.com/ebaymotors/ws/eB...d=242677731197
Old 06-25-2011, 09:38 AM
N20GMC's Avatar
Got that ^^^^^^^ slip yoke installed with the solid spicer u-joint that are the same size as the stock ones so no conversion joint was needed. Got it balanced also. The driveshaft fits just fine but in a perfect world it would need to be shortened like .375. If you did shorten it that much it would be perfect.
Old 10-01-2011, 07:15 PM
cfaluck13's Avatar
GM Turbo 400, TH 400 / 4L80E Transmission Slip Yoke | eBay
So with a stock driveshaft in my 2002 4l60 rcsb and this yoke will work fine without shortening the shaft even though the 80e is longer? Or is just the mount location further back on the 80 e since you have to extend the crossmember back?
Old 10-03-2011, 03:35 PM
N20GMC's Avatar
I got that yoke put on my stock DS and it works fine. My truck is a 04 so I don't know if yours is different. But like I said if you shorten the stocker like .375 witch is 3/8ths of a inch it would be perfect.
Old 10-03-2011, 05:30 PM
LsF-150's Avatar
same here, that yoke and stock shaft...this is on a crew cab...when i was researching my swap every thread i found the rcsb guys had no problems (2wd that is)
Old 10-14-2011, 12:16 PM
so the longer 7" yoke would work???? there is a 5" and 7" from what i saw on ebay not that i would buy and trust one on there
Old 10-14-2011, 05:32 PM
LsF-150's Avatar
Yes the 7" yoke, you will have to shorten it a little bit but the other one is to short (thats what i gathered from my research) everyone says get the longer one and shorten if needed...thats what i did, so far so good, also that yoke uses the rear u-joint to adapt to the shaft.
Old 10-14-2011, 06:47 PM
foose04's Avatar
I got this big fella. So far so good.
Turbo 400 Big Bad 1350 Super Strong SPICER Slip Yoke
Old 10-15-2011, 04:46 PM
else
Im alost ready to take my 4l60e out. This would be the last party that I would need to complete my 4l80e swap on my ext. Cab silverado. I know that I have a 2 piece driveshaft, but will this be the right yoke?. Thanks.
Old 10-15-2011, 06:50 PM
foose04's Avatar
Yep works great in my lil 80e and lives with a trans-brake and 600+TQ.
Quick Reply: 4L60E to 4L80E swap on a RCSB, driveshaft question
