4L60E to 4L80E swap on a RCSB, driveshaft question
Old 06-20-2011, 11:14 PM
TXjeepTJ's Avatar
Default 4L60E to 4L80E swap on a RCSB, driveshaft question
I can't seem to find a straight answer, some people say you can use the stock shaft, then some say you have to get a custom one made. Can someone clear this up for me?
thanks!
Old 06-20-2011, 11:26 PM
LaCamionetaGris's Avatar
i have the same exact truck as you do, i did the swap and used the stock shaft i just modified my crossmember, change the electrical connections and swaped to the stronger 1350 yoke, i've been driving it for over 1yr without any issues
darkirish63 (10-05-2019)
Old 06-20-2011, 11:29 PM
TXjeepTJ's Avatar
awesome thanks for the info, I'm guessing the 6L80E is the same length as the 4L80E? This stronger 1350 yoke, specs on it so I can find one?
Old 06-20-2011, 11:45 PM
ok well idk if the 6l80e and the 4l80e are the same lenth. as far as the yoke i just bought the yoke for 2006 2500HD truck @ autozone they already come with the 1350
Old 06-20-2011, 11:53 PM
heres a link of what ur looking for...
http://www.summitracing.com/parts/ST...n/?prefilter=0
Old 06-21-2011, 10:41 AM
TXjeepTJ's Avatar
was autozone cheaper? or just about the same price?
thanks!
Old 06-21-2011, 03:13 PM
N20GMC's Avatar
I am going through the swap right now. And I have pretty much the same truck. I bought a th-400 HD slip yoke from the same company I bought all my transmission parts from. But you have to make sure you get the long 4l80 slip yoke, because the shorter
th-400 is gonna be to short and you won't have enough spline engagement with the short one. The stock 4l60 slip yoke is like 5 inches long. And the short th-400 slip yoke is 3.5 inches long. So I am sending the short slip yoke I already bought back and getting the longer 4l80 slip yoke. Then you will have to use a conversion U-joint to go from the bigger 4l80 slip yoke to the smaller 4l60 drive shaft.
Old 06-21-2011, 03:27 PM
kazfan30's Avatar
You ever run that thing again LOL... since you intercooled and all?
Old 06-21-2011, 05:56 PM
TXjeepTJ's Avatar
after going intercooled I ran a second faster in 1/8th mile, but still slow as hell... I ran equivalent to a 14.5 second in the 1/4 mile. It has been extremely hot though. 2 weeks ago a cold front came through so I drove it out at around midnight with a temp of about 60 degrees outside, it woke up apparently because it blew my 4l60e lol
Old 06-21-2011, 06:03 PM
TXjeepTJ's Avatar
man sounds like a headache! could you PM me info on the company?
Quick Reply: 4L60E to 4L80E swap on a RCSB, driveshaft question
