4l60e to 4l80e swap exhaust routing.
#21
formerly Emmerich 5.3 (2013-11-30)
Yeah that's why installed the Sonnax line to lube pressure regulator. It doesn't stall the motor anymore but who knows if it was a 100 percent cure. I think that all has to do with cooler line flow.
#24
Thought about something, check inlet and outlet temps of your cooler, as in if the feed line is same temp as your return line, or cooler or warmer... If theres trash at the inlet of the cooler blocking flow the cooler would be cool to the touch... The inlet should also be slightly warmer than the return... Trans fluid unless under extreme conditions shouldnt really be necessarily hot to begin with, not like coolant or oil would get....
#29
That's a tough one cause the factory gauge through hp tuners sits 10-20 degrees higher than the autometer. But going back to the original reason for this post was the exhaust crossover. The factory temp sensor inside the pan sits just about right above the crossover. If I point the infrared gun at the pan where the crossover is it reads about the same as the crossover right around 250 degrees when the front of the pan reads 150. I bet there isn't a 1/32 gap between the crossover and the pan. I mean it's close if not touching. Also I forgot to mention when I point it at the converter it reads 210. This is all with the truck running btw.
