60 to 80 swap
Old 01-11-2011, 12:17 PM
JMF05LS's Avatar
Default 60 to 80 swap
First off I'm new to the site, my compliments from what i have read so far wow lots of info.
On to business i have a 05 Silverado 2wd std cab short wide bed 5.3, 4l60e trans w/transgo shift kit 3:73 rear end w/true trac, long tube headers, larger injectors, and a custom tune.
6 mths ago the out put shaft on the 60e broke, i replaced it with a built 65e now it broke. I dont want to waste more money on this trans, is the swap to a 4l80e the answer?
Your input is welcome. Thanks Jeff
Old 01-11-2011, 11:17 PM
I have a gauge for that
Atomic's Avatar
Historically the 80e has far fewer problems than the 60e, especially behind some big power....but less guys have 80s than 60s... I just did the swap and am satisfied with it.
Old 01-14-2011, 04:37 PM
JMF05LS's Avatar
Default Done with the 4L65E
I'm on my third 65e, out put shaft breaks both times and i don't want to do this again. Unless i learn of something else its going to be the 80E swap. I have been reading on hear for hours still have not found the swap info I'm looking for. I'll keep reading.
Thanks for the input Guys
Jeff
Old 01-14-2011, 04:47 PM
Banned
Andy @ FLT's Avatar
Billet output shaft ? we have them....
Old 01-14-2011, 04:59 PM
JMF05LS's Avatar
Thanks for the info. i have to ask what is next to break in the 60? If i up grade the out put shaft is there other weak parts?
Old 01-14-2011, 07:56 PM
Laid Back
Beatdown Z's Avatar
I have a feeling that I'll kill an input/output shaft one of these days. When it happens, I'll probably run the 60E one more time, then go 80E or less power.
Old 01-27-2011, 09:58 AM
chris092183's Avatar
Jeff
https://www.performancetrucks.net/fo...d.php?t=424904
Old 01-27-2011, 10:03 AM
pitbull985's Avatar
i just done the 80e swap and am pleased with it....worth the time and money to swap to know it wont break!
Old 01-27-2011, 10:08 AM
pitbull985's Avatar
what ques do u have???
Old 01-27-2011, 02:53 PM
nonnieselman's Avatar
I went thru about 15 4L60Es before i went with an 80E..
No problems since.. also a very hard shifting 60E will kill the output shaft very quick. that was one of my problems, i learned later on anyway.
The swap is very very simple..
All you need is a complete trans, TC, dipstick, shifter bracket and Flexplate for 80E.
Mod your Crossmember and bolt everything in,, get a TH400 Yoke and i think you have to get your DS shortened.
Wiring is easy..
https://www.performancetrucks.net/fo...d.php?t=413157
Quick Reply: 60 to 80 swap
