4.3l 4l60e
4.3l 4l60e
So I blew the trans in my truck will I have problems if I use one out of 2000 Silverado with a 4.3l? Mine has a 5.3l I know I have to swap converters.
i've been told by my tranny guy that yes it would work with a ls converter but the v6 one has one less steel or clutch or something meaning it was weaker
Ok, I read that you can tell a 4l65E by the bolt hole in the middle top of the bell housing. Taken someone hasn't switched bell housings I guess.
There is an LS based converter /input. And an LT converter /input. You can't swap the two without doing all 3. Here is why. The Bellhousings do interchange. The LS based trans is a half inch longer than your LT based 4l60e. The added length is all in the Bellhousing. I tried to swap them and found out the hard way. You can put an LS input drum, converter and Bellhousing on the LT trans, it will just be A Bit longer. So you can put LT parts in the LS trans and it will be shorter.
