4.3 4l60e vs 4.8/5.3 4l60e - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 05-09-2011, 12:39 PM   #1
Default 4.3 4l60e vs 4.8/5.3 4l60e
Are there any major differences between the two transmissions? I have searched and found one post saying the bellhousings are different. Is it a major difference, or just the one bolt that wont line up, and if so, would it be fine to leave it out.
I have a 4.8/nv4500, and am looking to go to an auto. I have found a 4l60e/tc out of a 03 blazer with low miles and a good deal and want to make sure that this will hold up behind the 4.8. The engine will stay almost completely stock, but there is a big difference in the hp between a 4.3 and 4.8.
brantb is offline   Reply With Quote
Old 05-10-2011, 11:07 PM   #2
Torque is almost the same, though, and that's what'll likely kill your transmission.
How did you get the NV4500 behind the 4.8? Usually the 4.8's had the NV3500, same thing the 4.3 had.
Unless things have changed, you SHOULD be able to bolt up a 4.3 transmission to the 4.8... But I can't say for sure 100%
drperry is offline   Reply With Quote
Old 05-11-2011, 11:08 AM   #3
hog
If the only difference is the 1 bolt hole difference, thats not an issue as teh dowels take most of the rotational torque.
I think there is a difference in the input shafts of the 4.3 and GEN 3 engine 60e.
I am running a 4.3 trans and TC behind my L31, but thtas different than your GEN 3 engine.
There are a couple kits that can be used to iubstall any 4l60e behind any GM engine.
http://www.pacificp.com/forum/viewto...ghlight=hughes
GEn 3 engine in front of a trans originally designed for GEN 1/2 engines.
http://www.crateenginedepot.com/stor...roduct_ID=2399
Installing a GEn 1/2 engines in front of trans mission that were originally used in front of GEN 3 engines.
http://www.crateenginedepot.com/stor...-P1812C43.aspx
peace
Hog
hog is offline   Reply With Quote
Old 05-13-2011, 06:39 PM   #4
thanks for the replies. I figured from all the searching and other posts on here that it was possible, but wanted to make sure. I cant get the guy back on the phone, and he is failing to send me pics of said trans, so i have searched again.
Now i have found a trans and tcase out of and 02 trailblazer and 07 trailblazer ss. Again from my searching, i think that this one will bolt up, but is the wiring going to work? My 4.8 is an 02. Is this the same 4l60/65 that is behind the v8's, or will i need the same 6.0 flexplate like i would need with the 4.3?
Is there a big difference between the years? What about the tcases?
the 07 has 15k miles, and the 02 has 67k. Im sure that i can get the 02 for around 300, maybe a little less, but if the 07 is that much better i will go with that one.
Old 01-30-2013, 01:31 PM   #5
MASS seller approved
anybody have any more info on this I can get 1 out of 03 that's behind a 4.3 just looking to put it behind my 4. 8 until I can my 40 &t case paid for
mitchellmade is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Transgo or sonnax Wolftrk99 GM Drivetrain & Suspension 48 12-03-2015 08:12 PM
Cam suggestions Wolftrk99 INTERNAL ENGINE MODIFICATIONS 14 10-02-2015 08:17 AM
4.3-5.3 motor swap wiring question... with a twist SLOPONY Tuning, Diagnostics, Electronics, and Wiring 11 09-24-2015 02:47 PM
5.3 build list and goals. Right track or no? pewter00 GMT 800 & Older GM General Discussion 8 09-19-2015 10:32 PM
Tags
43, 48, 4l60, 4l60e, 53, 57, bolt, difference, fit, gen, interchange, tc, tranny, trans, transmission
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
