14 Bolt 9.5" Rear End Dimensions
#21
Custm2500's Rude Friend
So I got the axles and lugs built to spec and I have moved on to the housing. Has anyone ever seen dimensions for the inside of the housing cover? Also I'm looking around to see how long the larger diameter axle tubes are that connect to the housing. I know that explanation sucked so check out the attached pic. Either of the two dimensions will work. Thanks
This is from an 88-98 OBS 4x4 housing. 67.5 overall WMS-WMS.
19-1/2 across the casting.
22-7/16 from the casting to end of axle tube. Both sides are the same.
signguy62
07-27-2015 03:42 PM
