Can I change the mounts with the motor still in the truck? Just one side at a time right? Use a jack and a piece of wood on the oil pan and gently lift then remove and replace?
Issues doing that?
Chad
yes i did this last year. i made the mistake of unbolting both. DO NOT DO THIS. the engine fell over to one side . i somehow managed to get the mounts back up by myself. not fun. just unbolt one side, lift engine with flat piece of wood, replace. repeat.
at the moment i had only the short block (was swapping heads) so it was much less weight on the oil pan when i lifted the engine
