Better Exhaust? Better gearing?
I'm running a Borla pro X series 1 in 2 outs and it's too quiet, I've heard other trucks with the same cam and they sound much better on idle. What exhaust system are you guys using that helps Performance wise and helps give it a deep grunt. Also I'm planning to get some 29 inch tall wheels and I have a 4.56 gearing, should I keep it or drop it down?
11 Second Club
Swapping mufflers is cheaper then swapping gears, I run 4:56 gears my self, and 29-30" tall tires and it is quite wound up on the freeway, I have considered swapping the gears to something more rpm friendly. I don't mind the gears in the truck, but I would personally rather spend the money on engine performance then re-gear the truck. I run a true dual 3" system with turndowns before the axle. how tall are your are tires currently? What are future mods/goals?
bisqikss
02-23-2017 06:06 PM
MOBBN
03-09-2016 11:59 PM
