What injectors for more RPMS out of a TSP224R?
Old 07-29-2014, 09:46 PM
Wrecker 426's Avatar
Default What injectors for more RPMS out of a TSP224R?
So have a pre 2002 engine so smaller then 24lb injectors and would like to turn an extra 500-1000 rpm out of my engine if possible and was told it was going to be my injectors that would limit me. Everything is up to date in my signature, and currently tweaking the tune as it is. Looking for any help direction or suggestions.
Would these work:
48lb injectors
Old 07-30-2014, 10:46 AM
turboal1's Avatar
Default RPM's
you only need to change inj if your running out of fuel in the upper
rpm range . what is you cams top rpm ? where does your eng
quit making power ? have you dynoed it to see what you have know ?
don't waste your money on something you may not need. at the most
you prob can use 27lb inj from a 350 LS1.
Old 08-05-2014, 11:18 AM
That probably would have worked and thanks for all the further question to think about, never though about injectors until the week I started this thread.
based on 4000ft altitude I didn't need to go much bigger, but I move every couple of 3-7 years, so bigger isn't bad. Not exactly sure on cams max out put did see a dyno somewhere someone's engine topped at around 7,200, wether or not that's the case for my engine I won't know till I raise the limiter, which Jason@bb is working on.
Ended up getting stock 8.1L 36lbs@4bar(5.3stock psi) injectors from fuel injection connection, and a very good price, I thought.
Old 08-06-2014, 09:26 AM
turboal1's Avatar
Default RPM's
call TSP and ask what the red line is ? prob 6200-6500
cam determines RPM's not inj's did you install new springs also ?
Old 10-31-2014, 01:12 PM
SILVERBIRCH's Avatar
do you have the part number for them?
how much did they cost?
Old 10-31-2014, 04:21 PM
Jeebalow's Avatar
These are stock 8.1L truck injectors. Part number is there. It's what I'm running on my truck.
I also have a set of 2008 non flex fuel LY6 injectors that came with my nnbs intake I can get the part number for that later.
Old 11-27-2014, 12:56 PM
brandon6.0's Avatar
I have some 42# injector I could sell u. I've put down 480+rwhp with them spinning to 7200. Pm me if interested. ill let them go cheap since I'm going turbo now.
GXPJAY
02-13-2022 08:15 AM
stealthperf
09-18-2015 05:51 PM
GrooveCityZ71
08-31-2015 12:05 PM
Mossyoakglock
07-17-2015 08:30 AM
lo4x4
07-05-2015 05:58 AM
Quick Reply: What injectors for more RPMS out of a TSP224R?
