lost on fuel issue
lost on fuel issue
Okay so the truck is a 99 with a pro charger , cam , worked heads. I've had the truck tuned and it was running great then all of a sudden one day it started getting high fuel pressure 80 + psi . So I was told it might be the fmu . Toke that off seemed to fix it . Then started getting a little low fuel pressure so I put in a 255. Did a little better but now it will range from 28 psi to 80 psi when just driving and my fuel trims are all over the place when watching them .
I do have 60 # injectors also but everything else is stock for fuel. I've read that the 99 you can use the stock fpr since it runs off a vacuum reference on the fuel rail from the intake manifold.
Any help would be great before I go replacing stuff I don't need to yet .
Thanks again for any help .
Well I toke of the extra fuel pump and even replaced the fpr again just to make sure. But my fuel pressure will start at 30ish psi then slowly creep up to 90 100ish psi. Anybody have clue what it could be?
I was thinking the same on blocked/pinched line . I had to drive the truck home and when on interstate it would very slowly go down to 38 psi . Then once in stop and go would go back to 100 psi. when I've unplugged the vac line off the fpr it would have no change in fuel pressure.
I'm going off my auto meter gauge I have on my pillar .
I haven't had time to mess with it but I've driven it some this week and have noticed that its staying below 60 psi now. I was having one person tell me that it was in my tune since I had the truck tuned with the fmu and inline pump on it . Do you think that could be the issue ?
I didn't think the tune would do that but wanted to make sure. I've had it running then toke off the line for the fpr and nothing changed on my fuel gauge . I'm thinking of picking up a diff one and putting it right on fuel rail to see if its just my gauge messing up on me .
