In line pump WITH in tank pump
Yes it is possible, and it works pretty good too.
I have a stock in tank pump with a Walbro GSL 392 inline pump on the frame rail.
I made 603RWHP and I'm still not out of fuel yet. I'm sure I'm pretty close but still not losing fuel pressure.
Why is everybody so against the inline pump idea? I've had 1 for years and have never had any issues.
Also, how is it easier to do a bigger in tank pump than just mounting an inline one on the frame rail and running 2 wires your done?
It seems like a much easier method on the older 99-01 trucks than trying to figure out the whole venturi or hacking up the bucket.
I have a gauge for that
Because when you look at the flow data you dont get a whole lot for your money running pumps in series on these engines. The place where you would see an advantage would be little honda engines running 30psi+ of boost. You do get some flow improvement with series pumps, but not near as much as installing them in parallel or just a single higher output one. A walbro400 or 450 is about the exact same size as a stock pump, no hacking needed.
Read this if you get a free while and notice how flow changes with pressure https://www.performancetrucks.net/fo...p-flow-510434/
Ok, I see your point. I've been trying to figure out how to make a Walbro 450 work in a 01 return style bucket for a while now. So as a temporary fix (band aid) I've been using the GSL 392 inline pump. But it works.
