How does everyone have their aftermarket FPR mounted in a NBS ?
Old 08-25-2016, 03:16 PM
  #21
zblee's Avatar
Originally Posted by BlackGMC
Yep. You will fail technif it mounted to the firewall. That is why i mounted mine where i did.
cant tell in the picture, but what is yours mounted to?
_zblee
Old 08-30-2016, 02:02 PM
  #22
TOTM: January 2007
Last Call's Avatar
Mine is mounted to the head:
Old 08-30-2016, 06:04 PM
  #23
Jake75's Avatar
i like how you have it mounted to the head. Did you make a custom bracket?
Old 08-30-2016, 06:20 PM
  #24
blackedoutchevy22's Avatar
Placed mine on the firewall
Old 08-31-2016, 01:00 PM
  #25
TOTM: January 2007
Last Call's Avatar
Yes, just an L bracket out of metal.
Old 09-15-2016, 08:06 AM
  #26
t_ahan's Avatar
on the head!
Old 09-20-2016, 12:50 AM
  #27
chris99gmc's Avatar
I finally resorted to this setup and it's been working flawlessly for two years so far. It's reliable, Very easy to work around and retains the oem test port and is incredibly stable.
Might be hard to see, but it's a braided -8an hose from an Inline Bosch 044 mounted to a surge tank. -8an 90* fed into a T-union on the passenger side rail. The union splits to -6 hose(slight S bend for injector/rail offset) to the regulator, -6 90* out the reg fastened directly to driver side rail... Return line comes out the bottom of the regulator. The key is to use O-ring fittings going into the rail ends and use "Swivel" fittings everywhere else.
There's Plenty of room for Autometer sending unit and FPSS out the gauge port on the back of the reg. with a relief valve T'd in. With it set up like this, I can drop pull the pump relay and just crack the threads loose on the Feed into the rail and have enough space to tilt the motor as far as I want to drop the trans in under 2 hours.
Any regulator mounted to firewall is eventually asking for trouble.
Old 10-24-2016, 02:09 PM
  #28
zblee's Avatar
unded up mounting mine to the fire wall, cut out a piece of SS to make a bracket that fit over the existing grounding bolts . gave it a slight bend to keep the regulator upright and installed all the fittings and lines. working as it should now.
thanks all for sharing
_zblee
parks450
05-01-2017 07:56 PM
jbaum02
08-14-2016 09:08 AM
zblee
08-13-2016 07:40 PM
ironcityboom
08-03-2016 03:10 PM
Quick Reply: How does everyone have their aftermarket FPR mounted in a NBS ?
