Help with routing fuel?
Getting started on my fuel system and going with a BRFPR, I've done a ton of searching around and everyone seems to have their own idea of what the correct delivery to the regulator from the rails is... Out of the two images below number one is my preferred mainly to avoid excessive fittings and lines. So my question is do you guys see any disadvantages to running the setup up in diagram 1(my preferred) rather than 2?
I just finished my fuel system and I did it like the first diagram, seems like it's a tried and tru system that will handle high hp ,so I did it to save on the extra fittings and routing..
https://ls1tech.com/forums/conversions-hybrids/586763-fuel-pressure-regulator-plumbing.html
look at this like it has some good info in it.
Thanks man I think that's the way I'm gonna go I want to alleviate all that plumbing. I'm going all 8an with a 6an return
