Help needed, walbro 450.. please help...
I'm going to install a walbro 450 in my tank, the trucks an 03(return style). I have looked on here and thru google for the past 2 days. I know this has been gone over. I couldn't find the exact way that works, mixed reviews... I will be using the factory bucket, which was changed 2 years ago.
Now there is a few different ways to do it:
1. Cutting the bucket with the sock on the outside.
2. Do i put a sock on the pump inside the bucket and remove the stock sock.
3. Put the pump in without the sock and just let it draw thru the stock one...?
I did buy the racetronix harness for this swap so that parts taken care of. I also bought all the parts to run an aeromotive 13129 fpr and block off the stock one. I have all russell fittings and braided hose.
Yea, I did this all right after I posted and it has worked fine. The two drawbacks to it is after it sits it cranks a few times more before it fires since there is no check valve for the fuel to bleed back into the tank. The other is under a 1/4 talk if u launch it it starves. But those 2 are the least of my worries.
For the pump I pulled the old one out, opened up the venturi and pulled the lil plug out of the bottom. The 450 fits about perfect in the stock pumps spot. I had to trim a real small amount so the pump didn't pinch the filter too tight in the bucket when it snapped back together. From racetronix i also did buy a corregated pump straw, clamps, skinny walbro filter and also used the pump harness kit. I changed the stock fuel filter to a aeromotive 10 micron 200gph high flow filter. From there its a stock feed line to the passenger fuel rail and the rear drivers rail to a 13129 aeromotive regulator and to the return.
My tunes setup for a 50 psI base, at 12 psi I see 62 and no drop. Seems to work good so far, it's only been 3 months but so far so good. With meth now this trucks a total *******...lol...lol
Yea, I did this all right after I posted and it has worked fine. The two drawbacks to it is after it sits it cranks a few times more before it fires since there is no check valve for the fuel to bleed back into the tank. The other is under a 1/4 talk if u launch it it starves. But those 2 are the least of my worries.l
i have pretty much the same set-up as yours but im thinking i have an issue somewhere. i have a 450lph in my 01 bucket and am using the stock lines up to the fuel rail. i have the factory regulator blocked off and an aeromotive adjustable regulator in line with the return lines but my fuel pressure has a huge constant fluctuation from like 40psi to 65 pis when the truck is running. any idea what might be causing the fluctuation?
Funkster
06-03-2016 04:26 PM
05chevy04yfz
03-18-2016 04:07 PM
