FBO LQ9 fuel pump question???
Old 01-20-2015, 09:54 PM
gansoh_hdss's Avatar
Default FBO LQ9 fuel pump question???
hi everyone I have a 2002 Silverado rcsb that I will be doing lq9 swap on it!!
mods are 228/232 cam, full cnc'd 799 heads by AI, 90mm tb with a nnbs intake mani right behind it, efans,3800 circle d stall, efans ,longtubes, ls7 injectors, basically will be 11.0.1 compression. I was wondering if my stock FUEL PUMP will be good enough for this set up or I will need to upgrade?? all info will be greatly appriciated
Old 01-21-2015, 02:37 PM
zachm89's Avatar
You'll probably want at least a Walbro 255 in there with the mods. If it was just a stock 6.0 you were dropping in you could get away with the stock pump.
Old 01-22-2015, 12:36 PM
53bowtie's Avatar
I agree with the above but would also look into the AEM 320LPH pumps that SDPC have to offer. They give you a bit more flow for roughly the same cost. And they have one that is E85 compatible if that's anywhere in your future.....
Old 01-23-2015, 05:25 PM
GREENSIERRA's Avatar
I ran my stock pump with a LQ4, 230-238 604 604 cam, TBSS intake, 42Lb injectors, 10.8compression, PRC 2.5 Heads, long tubes etc.... it did just fine
I am not sure of the difference in stock pumps between ours years tho.
Old 01-30-2015, 12:00 AM
hey guys thanx for the all the info, been very busy well I ordered a walbro 450 ehich is e85 compatible and just got it yesterday and I am planning on going e85 later on also!!!! any feedback on this pump my tuner recommended me but just wondering what things have you guys heard about it?
Old 01-30-2015, 11:19 AM
tim wellington's Avatar
Default pump
good pump. just upgrade your wiring .pump will burn stock wires
Old 01-30-2015, 07:53 PM
What type of wires do you recommend?? Im a newb at this fuel system stuff!!
5.3lSilverado
25
08-29-2016 12:48 AM
slowlsx
08-13-2015 08:28 PM
Sexyrado327
08-02-2015 04:08 PM
MS3Z
07-30-2015 06:17 PM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: FBO LQ9 fuel pump question???
