Dual Walbro 450s in 04-07 Tank
What's your setup consist of?
My dual Walbro 400's are working flawless. I'm not near as fast as some of you guys but I believe I have plenty of fuel. I have ran my tank down to as low as about 1/3 of a tank. I don't dare try it any lower. I usually have it at 1/2 tank at the track with no issues.
I ran my vent up to the filler neck. It seems to be working great. I have filled the tank up quite a bit in the last 3500miles and never had a problem getting it full
On the sending unit. I tried swapping the sending unit wires and ended up shorting out the sending unit. Not sure if it was a result of the swap of the wires or I bumped the sending unit to hard. The metal prong that makes contact on the bucket from the sending unit pretty much vaporized after I swapped the wires. And the sender was working before I swapped the wires, just the gauges was backwards.
Anyone have p/n’s for the 04-06 tanks, on the bottom stamped into the plastic? There’s a GM junkyard with a handful of tanks but not sure what years they came out of. I tried cross referencing the p/n’s online but came up with nothing.
