Any ideas for an upgraded DI in tank fuel pump
Old 10-13-2016, 09:31 PM
Registered User
r44guy's Avatar
Default Any ideas for an upgraded DI in tank fuel pump
Looking for some options for an Direct Injected 6.2L fuel pump? To make a long story short I have a 15 Silverado with a striker crank, cam with higher lift HP fuel pump lobe, Z06/LT4 HP Pump, fuel rail lines to the injectors, and Injectors, OEM fuel pump, aux. external secondary pump activated off of a Hobbs switch when the switch sees 2-3 PSI of boost from the TVS2300. Flex fuel sensor for the E85 tune and alky methanol injection. Wondering if any one has replaced the factory stock in tank pump with another pump and how the fuel pump control module reacts or if just needs to be deleted in the ECM. Thanks for any help or ideas.
Old 11-04-2016, 10:07 PM
ZO6Ted's Avatar
My pump and module went out recently.I was told by a local shop that does mainly Procharger high hp builds (1-1.5 k whp) that an external pump is all that is available.
speedy.5013
08-15-2016 05:48 PM
spudz
07-25-2016 07:42 AM
XL7
07-22-2016 01:34 PM
tgui
07-21-2016 09:53 AM
xrevx1
07-20-2016 11:41 PM
Quick Reply: Any ideas for an upgraded DI in tank fuel pump
