2001 Silverado FPR & Injectors with Stock rails Install
Stupid question, but what do you have screwed into your bypass? Could you not just machine a plug for the factory fpr and put it in. I may have missed something when I was reading. I'm looking to upgrade from the stock one and like what you have done. Thanks for the info.
But yes you could make that a exact plug without the threaded part for the sending unit.
Its his sending unit for his fuel pressure gauge screwed into the bypass. If I'm not miataken, you have to have that relief cut out on the inside of the plug for it to work. If not you'd pretty much have a return less system?
Well it's 5/8" wide and not quite 5/32" deep, not including what the tip of the bit itself will take out. I guess I'll give it a shot. I'm going to try to run my factory for a little while. Do you know what size gauge is that that screws into the front of the regulator by chance?
I figured out what I was looking for. I realize my post was somewhat misleading. Thanks for your help. I also figured out lingenfelter makes one of those bypasses...
I just typed ls fuel pressure regulator bypass in Google and went to searching. It had a picture of one at the top. Hovered over it and it said lingenfelter brand. I clicked on it and it was what it said it was. I'll try to post a link in a little bit
Try this and see if it works
LPE Fuel Pressure Regulator Plug Corvette LS1 LS6 LS2 LS3 LS7 03-13 - Lingenfelter Performance
