Foreign Performance Discussion Nissan, Toyota, Honda, Mitsubishi, Range Rover
2005 Honda Civic wheel humming sound
Old 01-14-2010, 12:21 AM
Reloy's Avatar
Question 2005 Honda Civic wheel humming sound
Hey folks,, along with a few gm trucks, I also have a civic car as the title shows. I bought it when it had 6k miles , and i couldnt be happier with the reliability. However, around 50k miles ago, i started hearing a humming sound (i believe its coming from the wheels or tires). Recently, when i apply the brakes it sounds more intense,,and the humming sound starts at around 40 mph. My cousin recently rode with me and he claims its the wheel bearings. Has anyone experienced such encounters? I now have 147k miles on it...and i've never fixed or replaced anything except tires and a few air filters... thanks in advance.
Old 01-14-2010, 01:56 AM
AJII's Avatar
More than likely wheel bearings. See if you can narrow it down to a certain wheel.
Old 01-14-2010, 02:13 AM
Where's the Beef?
viciousknid's Avatar
Wheel bearing would be my first guess or CVC going bad
Old 01-24-2010, 05:34 PM
ws6ls1's Avatar
Its a wheel bearing more than likely. Narrow it down to which wheel its coming from. Its a simple fix. Just remove the hub and press out the old bearing. Take a cutoff wheel and cut the bearing race off the back side of the hub. Press in the new bearing but make sure that when you do the magnetic side faces the inside of the car. Being a Honda tech I see people put wheel bearings in backwards all the time. When you do that you not only get to buy a new bearing but you get to replace the wheel sensor too.
Old 04-17-2010, 08:46 PM
Reloy's Avatar
I jacked the car up and everything seems secure... I couldnt move the wheel up or down or side to side... no play in it anywhere. Could it still be the bearings?
Old 06-07-2011, 12:10 PM
travieso's Avatar
for sure it's the wheel bearing , i just replaced the wheel hub assembly on my 2000 Honda civic, and it had the exact same symptoms that you are describing. after i went ahead and installed the new wheel hub assembly the noise/humming/rattling went away. hope this helps you out.
hartinclay
08-02-2015 06:44 PM
Ammadien
07-22-2015 08:50 PM
atxlt
07-20-2015 11:06 PM
abey15
07-13-2015 02:20 PM
Quick Reply: 2005 Honda Civic wheel humming sound
