Oil changes
Old 08-03-2010, 06:48 PM
mhotrodscooter's Avatar
Default Oil changes
I own a 05 Honda CR-V, I drive this to work, which is out in Odessa, Texas! This ride is 735 miles one way! I'm having to change the oil every month! The question is! I use regular oil castrol 10w-30 would it be better to go with a synthetic oil to get more mileage between oil changes?
Owner's manual says to change oil every 10,000 miles & filter every 20,000 miles in normal conditions!
Change oil every 5,000 miles & filter every 10,000 miles in severe condition!
Does Honda got a miracle oil r do they just want u to wear it out before it's time?
Any suggestion will be helpful thanks!
Old 08-05-2010, 05:56 AM
Somebody
Old 08-05-2010, 07:00 AM
Resident Retard
BlackGMC's Avatar
Personally i change the oil in my truck every 8k, and the filter ever 4k (i top off the oil when i change the filter only)... BTW my truck sees a fair amount of abuse...
Old 08-05-2010, 02:59 PM
11 Second Truck Club
fastrt's Avatar
I knoe some that go by the oil change light on some gm cars and trucks and never have a problem. 10-15k oil changes. On a *******(no offense), I would do what the book said, or call a dealer to see if that is right or a misprint. my *******(see I have one too), I do 3-4k oil changes with high mileage oil, cause oil is cheap, and a motor is not. my truck see's 5k oil changes and a filter on both at oil changes. a 10k oil change will gum up you motro though. a syn oil will help if you want to go those long intervals.
Old 08-05-2010, 03:01 PM
Wearin' da big hat
00ChevyScott's Avatar
you drive 735 miles one way to work? WOW!
Old 08-05-2010, 08:36 PM
I think I'll just keep doing like I was! Fastrt is right oil is Alot cheaper then a motor! Only got 82k on it & would like to get about 200k more!
I do thank y'all for the input!
Old 08-05-2010, 08:40 PM
Yep it's paying the bills!
I make the trip 3x a month.
I work 14 & 14 so I'm out here to stay while I'm working!
lukn4trbl355
10-21-2015 11:19 PM
sTNT971
09-26-2015 04:22 PM
lxcoupe
09-25-2015 12:36 PM
69z-28
09-21-2015 07:31 AM
Velocity1
09-15-2015 11:29 PM
Quick Reply: Oil changes
