Anybody know how to do a tune-up on 2003 F-150 4.6? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 04-18-2008, 06:28 AM   #1
14 Second Truck Club
Default Anybody know how to do a tune-up on 2003 F-150 4.6?
Need to change the plugs, spark plugs, & coilpacks on a 2003 F-150 4.6. The damn fuel rails are over everything. Anybody ever done this? I'm just gonna jump in and see what I can do, but I was wanting to know if there was any easy how-to's or don't do's. Thanks.
Hemi Killer is offline   Reply With Quote
Old 04-18-2008, 07:59 AM   #2
truckmann's Avatar
Best way to do a tune up on a Ford---->>>Sell it and get a Chevy
I don't know. I heard those modulars (if that is what this one is) are a bastard to work on supposedly it's like a 3 hour job to change the plugs for someone that knows what they are doing.
Good Luck!
truckmann is offline   Reply With Quote
Old 04-18-2008, 11:43 AM   #3
203Cree's Avatar
For someone that knows what they're doing, it's abouta 45 min job on plugs. First timer, plan on a couple hours. Easiest thing you can do is pull the fuel rails loose.
203Cree is offline   Reply With Quote
Old 04-19-2008, 02:46 AM   #4
Quote:
Thanks for the info! Do I need to loosen and pull up the injectors, while leaving them attached to the rails?
Old 04-21-2008, 10:54 PM   #5
if you have a good wobble socket 7mm, you can do it without having
to mess with the fuel rail. The hardest one is #5,
Take your time and do one at a time, remove the coil. then remove the
plug replace it and go on to the next.
Good luck.
fordbug77 is offline   Reply With Quote
Old 06-01-2008, 08:08 PM   #6
Registered User
well on the expeditions with rear ac #4 is the hardest #5 is easy and who takes the fuel rails out? 7mm wobble and u get the cop's out with no problem (#7 has the fuel reg. next to get u push the injector towards the rear and if u need unplug the injector to gain access). I have done like 10 5.4L and 6 4.6L tune ups not to mention all the cop's replacements i have done. with an 1/4 air ratchet u should be able to knock them out in 45mins.
willcarsrule is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
biggest shot w/ changing timing? twake_410 NITROUS OXIDE 17 04-14-2016 09:58 PM
Possible to swap an 8.1L into a GMT900 truck? calsdad 8-Lug Truck Performance 19 02-03-2016 08:23 PM
Flowmaster Force II Cat-back Exhaust System for the 2015 Ford F-150 FlowmasterMufflers Ford Engine & Exhaust Performance 1 11-24-2015 01:00 PM
coolant overflow for boosted trucks 6.0l RST FORCED INDUCTION 16 11-23-2015 11:30 AM
Blew up my 4l80E, carnage pics inside!!! SloSVO GM Drivetrain & Suspension 8 09-30-2015 06:17 PM
Tags
03, 2003, 2005, 46, change, cost, f150, injector, plugs, rail, remove, silverado, spark, ss, tune
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
