A/W Intercooler - Coolant flow direction?
#41
why not dump a ton of meth on the deal?
#47
seems like more water is just a bandaid...it will take longer to heat the water up to the point that your IAT sucks, but on a street driven vehicle it's only a matter of time before the water reaches that point whether it's 1 gallon or 5.
I have a 5 gallon resevoir in my back seat and i can feel the heat coming off of it.
what mixture of coolant/water do you use? i hear 75/25 or even 10/90 water/coolant works better than 50/50
you could move the reservoir to the inside of the bed away from the engine heat. not sure how much of a difference it would make.
#49
Mod with training wheels
Cool side HE>IC temp
Hot side IC>HE temp
pump flow rate..or just 'more' or 'less'
And then watch for the following conditions:
Hot side temp too low (relative to IAT): inefficient/small IC
Cool side temp too high (relative to ambient): inefficient/small HX
Temps too dissimilar: pump flow may be too low and not utilizing all potential heat absorption/rejection capacity of HX and/or IC (unlikely)
Temps too similar: pump flow too high and/or HX/IC maxed out in current configuration for current blower heat output
Basically it boils down to getting the baddest intercooler and heat exchanger you can and tuning your pump flow for the capability of both working together. What I would do is get those two sensors rigged in and get some data on it. Then figure out the real world relative efficiencies of the IC and HX under various boost levels (as best you can). Compare the sensor temps to each other, hot side to IAT, and cool side to ambient. If hot side temp is very close to IAT, or at least a smaller difference than cool side vs ambient, then you can probably stand to run a higher flow rate pump. If cool side temp is closer to ambient than hot side is to IAT, you may need to turn the pump down or run a smaller pump (at that power level). A variable speed intercooler pump would be optimal as long as you can determine what speeds it needs to run at and when.
We could always model this in MATLAB or excel (gasp)...I could probably use a math refresher I don't really get to work on thermal problems too often. Im surprised Richard hasnt already done this??
