Twin Berserkers
Old 07-01-2007, 12:50 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Default Twin Berserkers
I've decided to lift the veil of secrecy around my twin build up (translation: finally got batterys for the camera and decided I take the pics BEFORE going out to work on the truck for 10 hours...)
Here we go:
Since I'm moving to Rochester NY, I added the ability to add cats to the exhaust stream or run straight pipes on track days. I used Magnaflow spun metallic race cats and Stainless Works long tubes.
Let me tell you how much fun it was to make this crossover... I had this silly idea of keeping all the exhaust up inside the frame of the truck, because I hate seeing stuff hanging randomly down. Yes, my berserker-perfectionism caused me a lot of grief here -- especially in creating the compound curves necessary to get the passenger side exhaust over to the x-pipe with the big *** 4L80E transmission in the way...
more below
(Edit: the pics kept going away -- hopefully these will be permanent).
I AM A MOTHERF*CKER
Here's the hidden exhaust in all it's hidden, pita, headache inducing glory:
Getting the x pipe to the mufflers...
The whole schmeer:
Those are Magnaflow 4" bullets by the way. On to the TURBOS...
Yep... still fabbing the wastegates (ok -- still picking the location for the wgs lol). I did have to use the BFH a bit for some adjustment to run the exhaust through here...
YAY!!!
(still more below)
(Edit: the pics kept going away -- hopefully these will be permanent.)
Old 07-01-2007, 12:51 PM
I AM A MOTHERF*CKER
And now, to talk about the parts that I spent the most ridiculous amounts of time on... Looks simple, right?... Heh. I did the baloney cuts on the tips with a hand held cut off wheel.
From the wheel well:
I almost burned the truck to the ground over this next pic... This is the clearence between the caltrac bar (that I'd forgotten was not installed when I fabbed the tips...) at ride height... At full droop, let's just say I can pick traction or exhaust from the turbos...
Turbo exhaust (and nice view of 13.5" tires )
The difficulty with mounting the turbos side-facing is a little thing called a drive-shaft... Here's my solution -- COBRAHEADs
And here's my version of twin cold air snorkels..
Finally a crappy pic of the turbos, top-down.
Th-th.. th-th-th... th-that's all folks For now...
Old 07-01-2007, 12:58 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Well where the hell are the "reserved pics" at?
Old 07-01-2007, 01:10 PM
.T.
.T.'s Avatar
Damn good thing you can weld! That's seriously tight.
Old 07-01-2007, 01:39 PM
kbracing96's Avatar
Lookin good! Now get busy and getter runnin!
Old 07-01-2007, 02:54 PM
GFYS and STFU
Spoolin's Avatar
That almost looks too good to work. Could pass off as a concept car that shouldn't ever be driven you know. Looks immaculate...I'm jealous!! Lol
Old 07-01-2007, 03:34 PM
KySilverado's Avatar
Damn buddy, you've got tons more patience than I have. A lot of hours under that truck! Looking good!
Old 07-01-2007, 04:28 PM
I AM A MOTHERF*CKER
Thanks for the compliments guys -- makes all those long hours in 100* heat worth while.
Old 07-01-2007, 04:34 PM
that is a SICK set-up man.... those look like ebay turbos to me... are they?
Quick Reply: Twin Berserkers
