trick turbo kit...(turbo upgrade)
Old 07-21-2015, 07:44 PM
Jake75's Avatar
Default trick turbo kit...(turbo upgrade)
I currently have the stage 3 kit on my 2012 GMC with the PT7475 with T4 flange. I'm wanting to upgrade my turbo what would be a good turbo to upgrade to with minimal if any changes? Looking to get around 800 rwhp with my upcoming 6.0 swap.
Also somewhere down the road i plan on buying a 06 regular cab to put the trick kit i currently have on my 2012 in the 06. Will this work? or what will be needed to make it work?
Thanks
Old 07-21-2015, 08:40 PM
Choda's Avatar
I believe byrdman went w a bw unit when he went for big power.
Old 07-21-2015, 08:45 PM
ezdaar's Avatar
Crank up that boost, Shoot the meth!
Old 07-21-2015, 09:07 PM
Truck Sponsor
TrickTurbo's Avatar
76/75cea. Bolts right up.
But 800 hp gonna need to spin it up. 20-23psi.
Where you at now in power and boost?
The Borg units are great. Require new down pipe and I would go ahead and do 46mm waste gate.
Old 07-22-2015, 03:59 AM
Jake75's Avatar
I'm at 14-15 psi right now making around 600 hp on 93/meth
would a 76/75 be adequate on on 6.0? any way i could get a 88mm to work?
Old 07-22-2015, 01:03 PM
gamble686's Avatar
This^^^^^^^^
Old 07-22-2015, 01:18 PM
GMCtrk's Avatar
Where do you dyno in Houston?
Old 07-22-2015, 01:39 PM
Jake75's Avatar
D3 performance
Old 07-22-2015, 01:40 PM
GMCtrk's Avatar
Originally Posted by Jake75
D3 performance
Everything cool there? I wasn't really happy with G-force
Also, I've seen a poster on ls1tech go to the PT82 I think it is....should be a bolt on for T4
Old 07-22-2015, 04:37 PM
Byrdman11's Avatar
S480 or s484 with a 96m turbine. Get Rick to do the downpipe and you want to disappointed.
Quick Reply: trick turbo kit...(turbo upgrade)
