Trick turbo installation and review
Old 02-10-2016, 12:32 PM
  #31
crashmymax's Avatar
Everything on the hot side looks good. Welds are all good and seems to be quality parts.
Attached Thumbnails Trick turbo installation and review-trick-turbo-kit-001-2-.jpg
Old 02-10-2016, 12:41 PM
  #32
crashmymax's Avatar
Any advice on what spark plug to use? Better upgrade those if needed before I put the manifolds on.
Old 02-10-2016, 12:53 PM
  #33
I have a gauge for that
Atomic's Avatar
TR6 at the hottest. B7EFS will be fine as well.
Old 02-10-2016, 12:59 PM
  #34
crashmymax's Avatar
Thank you.
Old 02-10-2016, 02:26 PM
  #35
Formerly ScreamingL
George C....'s Avatar
Br7ef youll want to use
Old 02-10-2016, 03:01 PM
  #36
Atomic's Avatar
Have you actually seen a difference on LS engines using a resistor type plug, George? I haven't, but just wondering if you have noticed something.
Old 02-10-2016, 05:10 PM
  #37
fastjweb's Avatar
Good question, I am still running tr6s at 15lbs, not sure if I need to change also?
Old 02-10-2016, 05:20 PM
  #38
crashmymax's Avatar
Had a little more time got the manifolds and crossover installed. Have to say the fit was perfect!!!
Looks like the heater hoses will definitely need rerouting and kind of concerned about the a/c line but I am guessing that's what the heat shielding is for. Not sure what ill do next but I am in no hurry since I found another vehicle to drive.
Attached Thumbnails Trick turbo installation and review-trick-turbo-kit-001-3-.jpg   Trick turbo installation and review-trick-turbo-kit-006-2-.jpg   Trick turbo installation and review-trick-turbo-kit-002-2-.jpg   Trick turbo installation and review-trick-turbo-kit-005-2-.jpg   Trick turbo installation and review-trick-turbo-kit-003-2-.jpg
Old 02-10-2016, 07:49 PM
  #39
crashmymax's Avatar
Also need to add customer service continues to be outstanding. Received text through out the day with tips and help with the install.
I have about an hour tomorrow morning to get something done. Think I am going to tackle drilling the oil pan.
Old 02-10-2016, 09:02 PM
  #40
smoketrail's Avatar
Where do you intend on drilling it?
Are you taking the oil pan off?
Quick Reply: Trick turbo installation and review
