Trick Turbo Gas Milage
So I'am interested in seeing what all you trick turbo guys are getting for MPG. I figured it would be interesting. Please post your
1. Engine size.
2. Trans/Torque converter size
3. Rear end gear
4. Turbo size/ LBS of boost.
Thanks!
1. Engine size.
3. Rear end gear
Thanks!
1. Engine size. bone stock 5.3
2. Trans/Torque converter size. 278 mm 3000 stall FTI
3. Rear end gear. 3:42
4. Turbo size/ LBS of boost. 70mm / 12 psi
Thanks!
Thanks!
Just did an hour straight at 74mph and got 20.3 mpg average. ;(
1. Engine size.370
2. Trans/Torque converter size 4l80e
3. Rear end gear 4.11
4. Turbo size/ LBS of boost. 76/75
old setup 8 lbs 18-22mpg 60lb injectors
new set up 10lbs 15-17mpg 80lb injectors
newest set up 15lbs unknow mpg
1. Engine size 6.0L (LS3 Heads)
2. Trans/Torque converter size YANK 3400
3. Rear end gear 3.73 w/ Trutrac
4. Turbo size/ LBS of boost. PT74/75 16Lbs
I have done two mileage tests. First one was 18 mpg and after a few more tweeks in the tune its at 21-22 mpg. Thats at 65-70 mph.
1. Engine size. 4.8L all stock
2. Trans/Torque converter size: 4L65 3k Circle D
3. Rear end gear: 3.42
4. Turbo size/ LBS of boost. 70mm/ 11psi
13 MPG city
19-20 MPG highway
13 MPG city
19-20 MPG highway
