Trick Catch can after 3000 miles. 2016 DI.
Resident Retard
My DI cadiliac CTS does about the same. Also make sure to run some fuel injector cleaner through the tank often. Like every 6-8k. I change my oil every 6k and i just got in the habit of buying some fuel injector cleaner when i buy the oil and filter. I can always tell a difference after it.
Does this mean your working on a turbo kit for DI motors?????
Well since you've worked on a few of these engines then, I have a 2016 5.3 question for you. Is there any way to get vacuum from one of these motors if you ditch the factory vacuum pump? I'm retro-fitting one in a 70 c10, and I had to ditch it to make room for a power steering pump.
The trucks we have done on the driver side mid way is where we pulled vacuum from.
