Top street performance intake manifold?
11 Second Club
I would put my money on the Holley intake, it is priced better, and the rails are included. I like the tapered plenum design over of the straight plenum.
Plus I'm sure Holley put some R&D behind it, not just "thrown together"
glass it to cover up all the tooling marks as you dont want to remove the ribs and then sand it smooth as it reduces the over all thickness is the intake lids thickness. NA not really a concern, but boosted its a baaaad idea.
also consider, shave, glass smooth then hydro wrap it. can have any design you want on it.
This cutaway image shows that the TBSS runners must be 14-16" long, where the fabricated manifold must have 3" long runners. One manifold is designed to give a torque boost in the rpm range that the engine was intended to be used, the other manifold was designed to look cool.
11 Second Club
I would bet that their R&D went like this: "Does that look cool?" "yeah, that will sell" "Should we dyno it" "No! We are trying to trying to sell them. If we show the dyno graph nobody will buy it"
Those runners are very short compared to any OEM EFI manifold, indicating they would only be helpful at rpm higher than you will ever rev a street motor. Long runners are engineered to boost ram air flow at low rpm because of tuned length resonance. Short runners are for high rpm.
I agree with with it being a "looks cool only" product, but I was not taking into consideration the total length runner size of the TBSS manifold. I was speaking of the height, but yes they are indeed short runners.
Well played sir
