Rear mount 3/4 ton
In-Zane Moderator
Rear mount 3/4 ton
Looking for any input on turbo sizing and see what budget ideas anyone has. I have a fresh LQ4 in my 2004 3/4 ton with a hotcam. It ties ok but I want more. I figure 5-7 pounds should work. I want to rear mount a single and use a dedicated oil system for it that will be mounted under the bed as well.
Any ideas for a snail that may spool by 3000 but not have a issue turning 6600 RPM? Not sure where to go on the turbo size since I have never tried to put something together that will come in quick and not need to put out 20 pounds.
Also wondering if I can get away with not using a innercooler at such low levels and being rear mounted.
In-Zane Moderator
Thanks for the reply. One guy said I would need a innercooler due to the head when towing. I may get a long short bastard and just have it in line with the charge side. Maybe a duct to move some air across it while moving.
I gotta look up the oil pump the rear mount guys are using. I'm assuming some thinner oil for the turbo is fine. Was going to run it through a trans cooler with a single fan pulling air across it.
I think I may take your advise and try it without a innercooler just to SE ehow it does. If IAT won't stay low enough, I'll adddress the issue then.
