Plastic intake manifold splitting= Holley high ram?
Old 05-08-2015, 12:03 PM
TAPyvehc93's Avatar
Default Plastic intake manifold splitting= Holley high ram?
So I went to go get my truck tuned this morning and before tuning it they smoke tested it. Well this thing was leaking all over the damn place from the seams. So now I guess I need to upgrade. Will the Holley high ram clear the hood and cowl on the nnbs or do I need the mid ram? Any other intake manifolds out there that I should consider? I want something that will put the throttle body as close to the stock location as possible(for cold side piping) and something that requires little modification to work(sensors, wires and such). NO FAST lol
Old 05-08-2015, 12:42 PM
I have a gauge for that
Atomic's Avatar
By seams do you mean the intake gasket area or the actual seems of the manifold?
Old 05-08-2015, 01:12 PM
TAPyvehc93's Avatar
Yes not the gaskets, the actual seams on the intake. Its holds boost fine, but blows out smoke during the smoke test.
Old 05-08-2015, 01:45 PM
Atomic's Avatar
I would suggest replacing the intake before spending a bunch on one you may not need. Having had both, the stock intake is much more driveable.
Old 05-08-2015, 02:42 PM
Jake75's Avatar
a high ram will clear the hood
Old 05-08-2015, 05:37 PM
TAPyvehc93's Avatar
Thanks man. I am assuming you have one installed? Does it have provisions for the Map sensor and for a BOV boost reference? Also, can we run the stuck TB on it? Also, how do you like your D3 tune? The shop I was planning on having tune my truck's tuner is moving so......
Old 05-10-2015, 02:52 PM
06 4.8's Avatar
You must be pats cousin?? He told me about this the other day. Def go with the hi ram
Old 05-10-2015, 04:43 PM
Slowest turbo build ever!
black00chev's Avatar
I'd listen to this man right here!
Old 05-10-2015, 06:41 PM
06 4.8's Avatar
Do you mind elaborating on what you mean more drivable? I was about to buy a hi ram for my DD turbo build on my lq9. I've been in a few vehicles that had them and they drove great but wasn't in them for long periods of time.
Old 05-10-2015, 07:08 PM
TAPyvehc93's Avatar
Right!? Pats running one and that bitch seems pretty drivable lol. I don't see how a high ram could make it less drivable. It "may" kill the bottom end some but I'm not to worried about that.
Quick Reply: Plastic intake manifold splitting= Holley high ram?
